Author Topic: Chirping and Timing Chain Noise  (Read 2641 times)
Offline scra99tch
« on: April 15, 2018, 11:32:14 AM »
2007 Vintage 32k
I have a slight chirping noise on startup when engine is cold only hear it when I blip the throttle.  After sitting all winter this happened last year and I had forgotten all about it.  This year same thing.  I crank the engine over for awhile as fresh gas makes its way to injectors, oil light goes out until it eventually fires.  I will let it run for a bit until I blip the throttle sounds like chirping is coming from the front of engine.
Also noticed excessive chain noise.  Something I suspect is I will need to look at tensioner but is there a possibility that cam bearing is a little worn, hence the chirping?
I have not noticed any metal chips in the oil pan after last oil change.
2007 California Vintage
Re: Chirping and Timing Chain Noise
« Reply #1 on: April 15, 2018, 11:59:31 AM »
  :shocked: I wouldn't think so..
Offline lucian
« Reply #2 on: April 15, 2018, 12:11:40 PM »
Alternator bearing perhaps? Or maybe just old or loose  belt.
« Last Edit: April 15, 2018, 12:17:36 PM by lucian »
« Reply #3 on: April 15, 2018, 01:02:55 PM »
^^^^^ I'll buy the loose belt theory.  :smiley:
Offline scra99tch
« Reply #4 on: April 15, 2018, 01:06:46 PM »
Which belt?
Offline Idontwantapickle
« Reply #5 on: April 15, 2018, 01:09:43 PM »
Crank mounted Alternator, no belts. Chirping could be vibration induced. Something up front on the frame or engine could be making the noise. Poke around while it does it and see if it stops making the noise as you put pressure on stuff bolted on around that area.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Online rodekyll
« Reply #6 on: April 15, 2018, 01:12:18 PM »
Where is the crank breather on that bike?  Could be the breather valve?
« Reply #7 on: April 15, 2018, 01:15:48 PM »
Check exhaust flanges, loose pipes squeak. Just an idea.
« Last Edit: April 15, 2018, 01:22:12 PM by guzzisteve »
Offline scra99tch
« Reply #8 on: April 15, 2018, 01:48:06 PM »
No change when clutch pulled in or out so I can rule out disc.
Just odd that it only happens when below 40 degs F.
Offline John Croucher
« Reply #9 on: April 15, 2018, 01:59:33 PM »
All the stock cam chain tensioner does is keep the chain from hitting the crankcase.  It has no pressure with the spring made out of a bent paper clip.  Replace it with a Valtek.
« Reply #10 on: April 15, 2018, 03:19:54 PM »
Hunter
Opps, it's a Vintage.. my bad. For whatever reason I was thinking it was a 1200..
