Author Topic: 2001EV Performance enhancements?  (Read 5765 times)
Offline drburt
« on: June 22, 2018, 04:56:04 PM »
My 2001 EV is the only Guzzi I've ever ridden (except for the quick/forgotten much about/didn't gas it much/ trial a friend's brother let me take a few years ago in his neighborhood on his older EV).
I'm satisfied with the performance of my 2001 EV, but I'm just curious if it could be better.
I have the cables for GuzziDiag but have never tried to use it.
Don't even know if it would work on my model.
Don't see any maps on http://www.griso.org/ for 1100 Cali EVs.
Are there multiple maps out there for better performance?
Is anything available or needed to make the 2001 EV perform better?
Inquiring mind wants to know.
Thanks,
Brent
Re: 2001EV Performance enhancements?
« Reply #1 on: June 22, 2018, 05:35:13 PM »
Not a whole lot of stuff out there for the 15M   unless you have a Sport.  They were using power commanders then the Europeans cracked the code to get in ECU but most were riding newer stuff w/CARC.  So that's why. BUT I know Beetle may be up for the challenge. He did a nice one for a Vintage, it's got twin plugs so real similar.
Doesn't hurt to ask him.
I went a different route, I needed an ECU so I bought a MyECU from Cliff in AU. It's totally adjustable.
I enhanced my EV w/open pipes & airbox and was plenty of extra zip.
« Last Edit: June 22, 2018, 05:46:28 PM by guzzisteve »
Offline drburt
« Reply #2 on: June 22, 2018, 08:37:38 PM »
Thanks for the reply Steve.
I just read that the 15M itself can't be remapped without burning a new eprom.
Did you use aftermarket pipes that are already "open" (without being too loud, my preference).
What did you do to open the intake?
Thanks,
Brent
« Reply #3 on: June 22, 2018, 08:53:05 PM »
Just Mistrals for an EV. Airbox top has 2  2 1/2" holes in it and a K&N. It isn't all that loud.
Read this---
http://wildguzzi.com/forum/index.php?topic=96648.0
Beetle just made one, same ECU that you have, same bike but a hydro, 15M is programmable.
« Last Edit: June 22, 2018, 08:59:26 PM by guzzisteve »
Offline Sheepdog
« Reply #4 on: June 23, 2018, 08:51:21 AM »
My Vintage has a 15M. I got my ECU reflashed by GuzziTech. Also, Beetle (a forum member) has a comprehensive variety of 15M maps. The prices are reasonable and the bike runs perfectly with Mistral H-pipe/Classic silencers, and a modified airbox. I wouldn’t say that the bike is more powerful, but it has a wonderfully linear throttle, a sonorous report, and no popping when decelerating. A reflash really makes a nice difference on a bike with a lean factory map and is essential if you make exhaust/intake modifications.
Online PeteS
« Reply #5 on: June 23, 2018, 09:38:16 AM »
At one time there was a Power Commander for the 15M. I suspect NLA now. I had a PC put together by Todd at Guzzi Tech for the earlier CPUs (8?) on my '98. At the time there were maps for the Harley TPS (less expensive alternative) and some type of after market exhaust. I was running Dunstalls on mine along with a K&N and Harley TPS. It made a significant boost in the mid range and with no popping and way better gas milage than the two chips I had tried, Moto International, and Joost's Misano chip. Both of these richened the mixture but barely improved driveabilty and killed gas mileage, usually in the mid '30s. With the PC I was getting mid '40s so it was a win win all around.
BTW back then everyone was saying to get around the poor low end driveabilty you have to keep the rpms above 4k. With my setup it would putt along at 1.5-2k rpms no problem. Mine felt and ran like a Harley motor.
« Last Edit: June 23, 2018, 09:43:48 AM by PeteS »
« Reply #6 on: June 23, 2018, 09:48:06 AM »
Is the 2001 a 15M, or a P8, ECU? The 15M can be remapped. The P8 need a prom.The P8 is a huge box under the seat. The 15M is a small box under the left side cover.
I think on the intake side it will be hard to beat that large stock airbox.
« Reply #7 on: June 23, 2018, 09:50:10 AM »
 Same motive unit as my Jackal , that series of FI and ignition mapping was pretty well sorted at the factory . Mine has Staintunes with a stock crossover , and honestly I have no idea whether the ECU has been altered at all . The old thing runs fine , it takes a 2 valve Lemans or a 4 valve anything in good fettle to really outrun it . Yeah , there might be a Shetland lurking in there somewhere , but unless you are willing to start experimenting it probably is gonna be elusive .
Online rodekyll
« Reply #8 on: June 23, 2018, 12:16:13 PM »
Consider non-engine performance enhancements.  Tires, suspension, and aerodynamics can be improved.
Online Vagrant
« Reply #9 on: June 23, 2018, 01:10:16 PM »
That stock air box is loud as it is. Put some holes in and you might not be happy!
Offline Sheepdog
« Reply #10 on: June 23, 2018, 06:50:31 PM »
On mine, I used a 1” holesaw and put 3 holes on the airbox top. In these holes I put Uni filtered vents. This holds the noise to a dull roar and keeps detritus out of the filter while opening up the breathing to match the Mistral exhaust. The sound is wonderful without being excessively loud.
Offline Ncdan
« Reply #11 on: June 24, 2018, 09:11:45 AM »
Thanks,
Brent
Brent, I'm trying to increase my knowledge of all this mapping and ECU aspect of motorcycles as that's the future of motorcycles so enlighten me, what's an "EPROM"?
Online PeteS
« Reply #12 on: June 24, 2018, 09:32:35 AM »
Eprom is a programable memory chip. Once programmed it can't be alterered. EEproms can be reprogramed. Eproms are old school today. Most of the 90s era Guzzis had eproms. I think the '99 Bassa was the first with the 15M computer which could be remapped to a degree. The EVs and Jackals carried on a few more years with their ancient 8 bit computers with eproms.
Eprom chips are usually in sockets so a new eprom could be programmed with a different map to replace an existing one. Getting it right for specific engine configuration is not easy and few were correct.
« Reply #13 on: June 24, 2018, 09:36:56 AM »
I used to change eprom chips in the P8 and the 16M in the day w/you had a selection.
There are other things that work, I did some testing and gave info to Techlusion w/they were in Navada.  All it is is a fuel box, changes the pulse rate of the injectors. It does not change timing or any signals from the other sensors. I have good luck using it.  For open pipes it just adds some more fuel.
« Reply #14 on: June 24, 2018, 09:38:51 AM »
 Jackals all had the 15 M , as did the 2000 + EV's . Just to clear this up .
« Reply #15 on: June 24, 2018, 10:00:23 AM »
The Jackal and Bassa had the 15M early on. The EV switched later. I suspect they were using up the old P8 parts.
I have a box full of eproms and a programmer for the old stuff. Even a UV lamp to erase the chips.
Online LowRyter
« Reply #16 on: June 24, 2018, 10:08:09 AM »
I'd think you'd need to port the heads, install larger valves, racier cam, perhaps lighten and balance the rotating assemblies, intake and exhaust mods and remap the whole business.  You might get another 10-20 hp.
Or perhaps you might just purchase a Sport or newer performance engine that will fit the 5 speed. Or perhaps upgrade to a 6 speed and go to a lower rear end?
In fact, changing the rear end gearing might be the simplest and cheapest way to get more grunt.
« Reply #17 on: June 24, 2018, 10:12:45 AM »
Erasable Programmable Read Only Memory   :laugh:
« Reply #18 on: June 24, 2018, 10:17:19 AM »
Thanks,
Brent
a 7:33 gearset for the bevel box.
Online LowRyter
« Reply #19 on: June 24, 2018, 10:19:06 AM »
wait?  what?    :wink:
(see above)
Offline Ncdan
« Reply #20 on: June 24, 2018, 10:57:39 AM »
👍 kind of the same thing as adding a SIM card to your MP3 for more room to add more songs?
« Reply #21 on: June 24, 2018, 02:16:33 PM »
SIM card in an MP3?
Offline Dean Rose
    • Twin Valley Riders
« Reply #22 on: June 24, 2018, 06:56:20 PM »
 :1:
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Online rodekyll
« Reply #23 on: June 24, 2018, 10:39:19 PM »
No, more like changing words in a paragraph.
« Reply #24 on: June 24, 2018, 11:25:56 PM »
wait?  what?    :wink:
(see above)
I guess we can agree to agree!
Offline Mr Revhead
« Reply #25 on: June 25, 2018, 01:57:19 AM »
If I was going to spend a grand on my EV this is what I would do. From all I've read it transforms the bike. I just can't justify the cost! Yet...
Online PeteS
« Reply #26 on: June 25, 2018, 08:27:01 AM »
fotoguzzi posted his dyno graph on this thread. If I had a bike with a 15M I would start here with what he did to his bike.
http://wildguzzi.com/forum/index.php?topic=96695.0
My experience is with the earlier P8 computer but if his runs as well as mine did you won't need to change the rear drive.
If you need more power than this then it would be cams and headwork $$$$$$ but at that point I'm not sure its worth it.
Offline Zoom Zoom
« Reply #27 on: June 25, 2018, 07:41:50 PM »
'98 and '99 EV's had the P8. There were no EV's imported for 2000. The "01 EV's came with the 15M.
John Henry
