Author Topic: elrctric center stand toggle switch orientation poll  (Read 4352 times)
Offline gearman
« on: October 06, 2018, 02:53:13 PM »
I posted pictures in my original post. My friend thinks I have it wrong.Do airplane gear have a universaL ORIENTATION?
« Last Edit: October 06, 2018, 03:01:51 PM by gearman »
Offline acogoff
Re: elrctric center stand toggle switch orientation poll
« Reply #1 on: October 06, 2018, 04:01:02 PM »
    The wheel shaped lever is always down for gear down and up for wheels up on the fancy airplanes that have disappearing wheels. But as long as you get it to operate what does it matter, you are the one using it. Every time I get these hecklers offering their suggestions I just ask them how they oriented the one on the one that they built and it usually shuts them right up.
« Last Edit: October 06, 2018, 04:04:53 PM by acogoff »
Marshall County Minnesota USA
Offline PeteS
« Reply #2 on: October 06, 2018, 04:38:23 PM »
Think of a common light switch. Rule of thumb is switch down is off, switch up is on. The idea is if the spring fails or in this case you hit a bump, you don't want to accidently turn it on which might happen if down was on.
Offline gearman
« Reply #3 on: October 07, 2018, 11:14:24 AM »
What??? only five members have an opinion? I need a bigger sample.Thanks
« Reply #4 on: October 07, 2018, 11:45:31 AM »
There is not option for rotary switch.
 :boozing:
Offline gearman
« Reply #5 on: October 07, 2018, 02:16:50 PM »
I don't know what kind of bump could flick a 40yo hd dpdt quality switch.These are very positive make and break switches. Not audio easy toggles.Actually the Guzzi content is it came from the dash on one of my Converts. It was made in Mexico in 1976.A well made switch.I guess the Italians did not make these back then.Thank goodness. :laugh:
« Last Edit: October 07, 2018, 02:23:25 PM by gearman »
Offline gearman
« Reply #6 on: October 08, 2018, 08:04:07 AM »
I don't get it. 176 views but only 7 votes.Is the question too difficult?Some one explain to me please.
« Reply #7 on: October 08, 2018, 08:38:26 AM »
Ok, most people really don't care how YOU actuate the gizmo YOU built. I voted down for down because that is the way it *should* be..  :smiley: but as long as the operator knows which way it is actuated, it'll be good.
Offline gearman
« Reply #8 on: October 08, 2018, 09:37:11 AM »
Ok, I get that, but I designed industrial machinery for40 years and always had to keep in mind how the operators would perceive my layouts.You would not design a car with the gas pedal to the LEFT of the brake pedal for instance.I built mine with the bat down for centerstand down which was logical to me. The few voters all agreed with that. Thanks for the input.My best friend who has a background in industrial design said I had it wrong so being open minded I started this poll.As you well know being a pilot. controls need to be intuiative or they can be dangerous.
« Reply #9 on: October 08, 2018, 10:01:05 AM »
One thing for sure, I would wire it , up or down, so it only extended in neutral or something like that.
« Reply #10 on: October 08, 2018, 10:18:39 AM »
Good point.
Offline gearman
« Reply #11 on: October 08, 2018, 10:45:21 AM »
Good point.
That would be nice, but there is no neutral. It has a cvt drive.The switch is in the glove box so a inadvert activation is omitted.A speed sensor on the rear wheel would work but the risk benefit ratio doesnt work for me. When I made the Landing Gear for Gold wings ten years ago I had a rear wheel speed sensor. But my controls were all digital which can be dodgy sometimes.
« Reply #12 on: October 08, 2018, 01:14:07 PM »
The reason foot controls on trucks and cars are standardized was that in WW1 there were so many vehicles flooding to the front from many manufacturers around the world it was so that anybody could drive them once they learned the basic orientation. I vote toggle down, stand down. Your poll question is confusing, that is the reason I did not vote there. OK, I reread it a couple times and assume you are starting with the stand stowed and are asking which direction the switch is to be thrown for the desired operation, stand down.
« Last Edit: October 08, 2018, 01:20:50 PM by John A »
Offline RinkRat II
  • Lake Powell AZ
« Reply #13 on: October 08, 2018, 01:50:03 PM »
  I'll go out on a limb here and say this, switch up, stand up. Switch down, stand down. Just curious as to your friend's engineering logic(oximoron) :evil: that your placement would be wrong?
      Paul B :boozing:
Offline Groover
    • Scooteropolis
« Reply #14 on: October 08, 2018, 01:56:53 PM »
To avoid confusion, I'd go with something a little more flush with a symbol - up or down, then it sort of doesn't matter, but in this case the red circle (down) would indicate off (parked) which could mean kick stand deployed.
Like this:
https://www.radioshack.com/collections/switches
« Last Edit: October 08, 2018, 02:36:22 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline gearman
« Reply #15 on: October 08, 2018, 04:26:28 PM »
      Paul B :boozing:
My friends reasoning is since I am RAISING the bike on the centerstand the bat should be up.
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #16 on: October 09, 2018, 01:01:01 AM »
Unless you are talking about the Johnson Bar on a Mooney  :grin:
Up (vertical) is down and locked, down (horizontal) is up.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
Offline Idontwantapickle
« Reply #17 on: October 09, 2018, 10:43:59 AM »
I did not respond to the poll because, in my opinion, you have missed an opportunity for a safer option: A momentary switch.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline gearman
« Reply #18 on: October 09, 2018, 03:13:05 PM »
I need my hands free to hold the bike.You gotta think these things through. :grin:
