Author Topic: measuring squish and threebond in place of gasket  (Read 2206 times)
Offline lazlokovacs
« on: October 18, 2018, 02:23:31 PM »
Hi all,
Got a spare 1100 engine on the bench.
Squish measured at .070  -.074
optimum is .040 or so I've read
Means I can lose a bit of cylinder height
I measured the base gasket at .025
Can I use threebond in place of the base gasket?
And will it get my squish near enough, or should I be looking at milling the cylinders?
Cheers
« Last Edit: October 18, 2018, 02:24:03 PM by lazlokovacs »
Online John A
Re: measuring squish and threebond in place of gasket
« Reply #1 on: October 18, 2018, 05:26:36 PM »
Yep, that's the "quick and dirty" way to do it and it works well. I used some flange sealant by Locktite but Threebond is good stuff too.
Offline lucian
« Reply #2 on: October 18, 2018, 06:42:51 PM »
 Was the squish not in spec originally?  Did you measure with the head torqued down ?   Just curios.  Perhaps thinner head gaskets are available.
Offline lazlokovacs
« Reply #3 on: October 19, 2018, 04:45:01 AM »
yes I measured with the heads torqued down
Offline lucian
« Reply #4 on: October 19, 2018, 06:04:11 AM »
If you drop the cylinder be sure there is not excessive wear  on the bores or a ridge at the top of the piston travel. It is better to plane the head as it wont change the wipe area of the bores. I don't know what the spec is for squish on the 1100s but .070 doesn't seem extreme. I would run it see how it goes. Easy enough on a guzzi to pull the heads and plane them it you get a lot of pinging. ( detonation)
