Author Topic: Aprilia RS660 concept  (Read 6779 times)
« Last Edit: November 07, 2018, 12:30:22 PM by Antietam Classic Cycle »
Offline flip
Re: Aprilia RS660 concept
« Reply #1 on: November 07, 2018, 12:49:39 PM »
I'd like to see a naked version of that!
North Carolina
« Reply #2 on: November 07, 2018, 12:51:34 PM »
Considering that Aprilia get over 200 HP from their V4, half that from a lightweight 660cc twin sport bike would be a whole lot of fun!
Offline Diploman
« Reply #3 on: November 07, 2018, 12:59:10 PM »
That looks serious.  Downdraft intakes, water-cooled, ultra compact.  This could be the basis for a fast, lightweight sports bike.
2015 KTM 390 Duke
Offline JohninVT
« Reply #4 on: November 07, 2018, 01:24:46 PM »
How do you get at the valves to adjust them?
Moto
« Reply #5 on: November 07, 2018, 02:08:09 PM »
Through the nose. You pay through it for someone else to do it.
Offline not-fishing
« Reply #6 on: November 07, 2018, 04:06:09 PM »
So where are the valves and how do you get to them for adjustment?
the only way I know it's right side up is the "Aprilia" on the side - which I'm assuming is supposed to be right side up
:laugh:
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline analog kid
« Reply #7 on: November 07, 2018, 05:19:23 PM »
Step #1: remove engine.
90 Mille GT
03 Aprilia Caponord
84 LeMans lll (project)
07 Breva 1100 (sold)
Offline Aaron D.
« Reply #8 on: November 07, 2018, 06:13:44 PM »
That same first step is needed on at least one other Italian bike I'm familiar with.
A lot of these bikes don't need a lot of attention to clearances. I wonder about this one
Offline Diploman
« Reply #9 on: November 07, 2018, 06:23:29 PM »
Maintenance accessibility of the engine is often an overlooked design criterion for designers who are seeking the most compact and lightweight machine, such as that pictured above.  My KTM 390 Duke is a lovely bike, but it suffers mightily from this "dense pack architecture" phenomenon, so much so that even changing a spork plug is an ordeal requiring much disassembly.  Checking and changing valve shims is, for the home mechanic, something of a torture.
We here often take it for granted, but Guzzi owners should be thankful for the superb accessibility of Guzzi cylinder heads and the overall ease of access and maintenance thanks to Guzzi's unique engine configuration.  Working on a KTM or Aprilia will give you a renewed appreciation for Guzzi!!
« Last Edit: November 07, 2018, 06:36:59 PM by Diploman »
2015 KTM 390 Duke
Offline Murray
« Reply #10 on: November 07, 2018, 06:53:28 PM »
Due to the very short valve train on DOHC motors there is literally not much room for movement unlike a pushrod motor. So you'll find valve check intervals will be around 20 000kms (12 000miles) and it is perfectly normal for the motor to not actually require a shim before 60 - 80 000kms. Looking at that motor you simply go through the top after pulling the airbox and tank some of the DOHC are setup so you don't even bother the cam chain when doing the shims.
Offline Diploman
« Reply #11 on: November 07, 2018, 10:22:29 PM »
If only it were really as easy as you suggest.....
2015 KTM 390 Duke
Offline JohninVT
« Reply #12 on: November 08, 2018, 03:39:52 AM »
If you take a look at the pictures of the engine in the frame you'll understand why I asked.
https://2yrh403fk8vd1hz9ro2n46dd-wpengine.netdna-ssl.com/wp-content/uploads/2018/11/2018-aprilia-concept-rs-660-first-look-4.jpg
« Reply #13 on: November 08, 2018, 08:34:14 AM »
24,000 mile valve adjustment.
Most riders will never ride far enough to have it done.
LOL!
« Reply #14 on: November 08, 2018, 09:10:35 AM »
Why would they put something that is a cross between a spoon and a fork in a motorcycle? :undecided:.........
 :wink: I know what you mean. :grin:
Offline Diploman
« Reply #15 on: November 08, 2018, 09:20:37 AM »
Muzz, the spork plug is there to ensure you don't exceed the bike's spork impedance capacity.  If you get an overload, you simply open the spork plug and drain out the excess...... :azn:
2015 KTM 390 Duke
Offline Roebling3
« Reply #16 on: November 08, 2018, 10:09:00 AM »
Avoid the valve issues and put a 2 stroke twin in its place. I read, some months back (perhaps it was Rotax?), that has a 2 stroke in development with FI + oil injection, direct to the bearings. It's alleged to exceed 2021 EU specs. A modern 650 2 stroke would put out 100hp or more. The bike, even liquid cooled, may not weigh 350#! I'd rather orange as the dominant color.
It's a race bike w/street clothes. But is your spine 'young' enough to ride serious hours? Years ago someone asked Dr. John Wittner why the Daytona's chassis cross tube wasn't closed. He responded saying; 'That's for a sandwich and your toothbrush'. (always a dentist?) Worth it for grins alone I have BTDT. I've back packed on the Daytona, the RS and many more yclept small bikes. When the grins were big enough I never felt discomfort.  R3~
Offline Murray
« Reply #17 on: November 08, 2018, 10:42:15 AM »
The thing that used to kill spark plugs was the lead in fuel so I'd expect the plug interval to match the valve adjustments.
« Reply #18 on: November 08, 2018, 11:38:37 AM »
Aprilia pairs the chassis with a comfortable riding position due to more upright bars and forward footpegs, and body work that provides added wind/weather protection.
Doesn't sound like it would be too radical.
Offline rdbandkab
« Reply #19 on: November 08, 2018, 11:58:08 AM »
Red engine cases..   :wink:
« Last Edit: November 08, 2018, 12:00:07 PM by rdbandkab »
Offline Roebling3
« Reply #20 on: November 08, 2018, 01:48:51 PM »
I love from where you cometh, Charlie! If I were to see one of those I'd likely put my more than lovely masseuse on retainer and sell a few Guzzi's. I've had a string of 2 strokes (1952 on)and lots of miles; still have 3. Two have a reasonably tolerated howl. They not only light me up, but when the occasional guy, mowing/raking his lawn, drops everything to punch the sky w/both fists, my day has been made. Still have an RS125. 270#. Goes like stink for its size. 22K miles. It's on the original 'spork' plug. Except for tires and cleaning the power valve 2X.
Those Ape folks know what they're doing.  R3~
Thank you for the pictures!  Good fortune.
« Reply #21 on: November 08, 2018, 02:07:12 PM »
Can a spork plug be retrofitted?  It sounds a most projaginate additional device to have fitted.  The Breva might be able to keep up with a 125 Aprillia then. :thumb:
Offline fossil
« Reply #22 on: November 08, 2018, 02:16:24 PM »
That should be Rotax. That´s exactly the technology they use in outboard engines for years now (Evinrude E-TEC) and also in snowmobiles (Rotax E-TEC). Rotax and Evinrude are both BRP - brands.
Greetings from Germany!
Thorsten
« Reply #23 on: November 08, 2018, 06:12:52 PM »
I just read, forget where, that it should make about 100 HP, and weight about 330#.
That'll be a helluva lot of fun on the track!!
« Reply #24 on: November 09, 2018, 08:40:03 AM »
« Last Edit: November 09, 2018, 08:40:39 AM by Antietam Classic Cycle »
Offline Tusayan
« Reply #25 on: November 09, 2018, 09:11:30 AM »
A north-eastern Italian vertical twin with an aluminum beam chassis, the result being a bike that handles very well but probably doesn't feel as good as a v-twin otherwise.  Where have I seen this before?  :grin:  Piaggio owns both names, they should call this one a Laverda.
« Last Edit: November 09, 2018, 09:16:34 AM by Tusayan »
« Reply #26 on: November 09, 2018, 09:40:40 AM »
I was thinking the same thing!
Offline vintage53
« Reply #27 on: November 09, 2018, 05:54:50 PM »
HI Charlie.
I was thinking the name "Gilera"
Piaggio owns that one too.  🤔
1977 Lemans
2004 V11 Coppa Italia
2010 California Vintage
Offline vintage53
« Reply #28 on: November 09, 2018, 06:00:25 PM »
1977 Lemans
Offline Roebling3
« Reply #29 on: November 09, 2018, 06:30:58 PM »
I've complained (including to A. Bampa), for years that Piaggio should allow MG to raid Aprilia's parts bins for off the shelf power train and suspension pieces. Ditto body kits from Ghezzi et Brion. They could have a sport bike w/very little investment, but w/character and modern handling. In fact: How distant can all the electronics for engines, ABS, TC control and instruments be from Aprilia to MG? Start with a set of fully adjustable fat forks, radial brakes. Start somewhere, for Pete's sake. R3~
