Picked up my new V7 Racer today. It shifts fine up and down however when coming to a stop or at a stop it will not go into neutral. Extreme pressure is required to move from first to second or second to first when idling at a stop. If I shut the engine off it goes into neutral no problem. The dealer seemed to think things were stiff and needed seating in but after a couple hundred km's it's just as bad. I seem to remember reading a post about a V7 with shifting problems but I can't find anything. Has anyone else had this problem? Other than that my first impression is this is going to be a fun little bike. It even manages to haul my fat a$$ around ;DThanks in advance for any suggestions.
Thanks Carl, I just went for a short blast (before the rain) and I adjusted the lever out a bit more. It was better. I hit neutral in a couple of rolling stops. Maybe it just needs some more time to loosen up.
I think someone mentioned that the gears are straight cut as well. Is that the case?
Regarding neutral - which one? ~; cr
Whisper into her left mirror that you're not really going to sell her. She may relax and loosen up.
be sure to set the slack at the handlever to the value that is requested in the owners manual,it shall be done with a warm engine IIRC.
