Author Topic: 850T Project  (Read 34804 times)
Offline smdl
850T Project
« on: February 24, 2013, 06:02:17 PM »
Greetings, all.
Well, with my Eldorado project winding down, I was beginning to miss tinkering with a Guzzi, and felt compelled to pick up another project.  So, last weekend, I brought this home:
http://tinyurl.com/cukt2wu
This weekend, I spent some time cleaning it up, giving it an oil change, and freeing up all the stuff that was stuck as a result of it sitting for the past several years.  In particular, one of the carb slides was completely frozen, and it took a bit of work to get it moving.  Once that was done, I was able to attach a charged battery, and she fired right up!  Before anyone gets worried, the engine is a 950 with iron liners, so no chrome to worry about.
The bike has a couple of issues that I hope forum members might be able to help with, so I will add posts about those shortly.  I'll also plan to post updates, now and then, as the project progresses.
Cheers,
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
Online Perazzimx14
Re: 850T Project
« Reply #1 on: February 24, 2013, 06:09:35 PM »
Greetings, all.
Cheers,
Shaun
Where's the project 850 you said you picked up ;)? It can't be the orange and white one in the picture cause that bike looks like a daily runner!
« Last Edit: February 24, 2013, 06:28:23 PM by Perazzimx14 »
Offline smdl
Re: 850T Project
« Reply #2 on: February 24, 2013, 06:25:46 PM »
As many know from buying bikes remotely, pictures can be deceiving!  Overall, it's solid, but it needs a LOT of work.  That's okay, though, as that is exactly what I was looking for.  I'm thinking of putting a sign up outside my garage that says "Guzzi Rescue".   ;D
Cheers,
Shaun
« Last Edit: February 24, 2013, 07:18:45 PM by smdl »
'61 Galletto
'24 Stelvio
Offline harrytief
Re: 850T Project
« Reply #3 on: February 24, 2013, 07:13:47 PM »
Excellent and congrats Shaun. Remind me ...where have I seen that bike before?
Harry
Offline smdl
Re: 850T Project
« Reply #4 on: February 24, 2013, 07:18:04 PM »
Okay, first issue that I'm hoping for some help on:
The previous owner had been struggling with some issues, and did not have the time/ability to work on it himself, so the bike had sat idle for some time.  He told me that the engine was making a rattling noise, and that several attempts had been made to resolve it.  I don't have all the details, but I believe this included valve train adjustment/work, rod bearings and at least one piston.  However, these efforts did not resolve the issue, and apparently an experienced mechanic had suggested that the engine "might have the wrong pushrods" in it.  Once I got the bike running, I immediately heard what they were describing -- an incredible amount of top-end clatter.  Now, please understand that I know what Guzzi's sound like as I have two others, including one with exactly the same engine.  I expected the valvetrain to be noisy, but this was truly unusual!
It is always very difficult to convey things like noises verbally, so I have made up a short video, and posted it on YouTube.  Not sure if this will successfully convey it either, but here goes:
http://www.youtube.com/watch?v=qawW6DV7WTs&feature=player_detailpage
Note that the noise is definitely coming from the top end, and is very loud on both sides, but slightly louder on the right.
I have already pulled the valve covers, and everything looks normal in there, but I will naturally check the clearances.  Once the engine cools down completely, I will re-torque the heads and complete a valve adjustment.  However, with the understanding that this has been attempted before, is there anything else I should be checking while I am in there?
As an aside, I checked compression today with the engine hot, and it registered 65 on left, and 110 on right (forgot to hold throttle open).  I will check again once I have everything adjusdted and balanced, but it looks like I will be spending some time on the inside of this engine.  Not really an issue as I would have done so regardless (just to be sure), and I am planning a few performance enhancements anyway.
Any thoughts would be appreciated.
Cheers,
Shaun
« Last Edit: February 24, 2013, 07:25:26 PM by smdl »
'61 Galletto
'24 Stelvio
Offline smdl
Re: 850T Project
« Reply #5 on: February 24, 2013, 07:22:31 PM »
Harry
Thanks, Harry.  Ummm, perhaps in your own garage?   :)  For those reading, Harry owned this bike a number of years ago (I also know the owner previous to him!).
Shaun
'61 Galletto
'24 Stelvio
Offline Two Checks
Re: 850T Project
« Reply #6 on: February 24, 2013, 07:49:11 PM »
Check the rocker arm shafts for wear. They and the arm bushings can wear out due to the oiling holes getting clogged with bits of stuff like timing chain tensioner rubbing block fragments.
My old T made a horrible sound and couldn't set the valves properly.
1987 1000 SPII "Il Duce' II"
Re: 850T Project
« Reply #7 on: February 24, 2013, 08:03:54 PM »
Looks like a a great bike! Keep us posted.
Cheers
Jim
Offline smdl
Re: 850T Project
« Reply #8 on: February 24, 2013, 08:11:40 PM »
Thanks, Two-Checks.  This is exactly the kind of information I was hoping for.
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
Re: 850T Project
« Reply #9 on: February 24, 2013, 08:14:03 PM »
Cheers
Jim
Thanks, Jim -- will do.  A few false starts, but I'm glad to be moving on something now.  By the way, I have really been enjoying following your V7S project -- truly inspiring!
Shaun
'61 Galletto
'24 Stelvio
Re: 850T Project
« Reply #10 on: February 24, 2013, 08:31:46 PM »
is the 850T a cult bike?
if so I'm an original member
Offline smdl
Re: 850T Project
« Reply #11 on: February 24, 2013, 08:38:11 PM »
Hey, Foto.  Not a bad cult to be a member of!  I have to admit, though, that I am going to be messing with this one.  I'm looking to build something a bit more sporting this time, so we'll see how things come out.
Question for you -- what saddlebags are those on the second picture you posted (and maybe the first)?  I have those exact same bags on my bike, and would be intersted to know what they are.
Thanks,
Shaun
'61 Galletto
'24 Stelvio
Re: 850T Project
« Reply #12 on: February 24, 2013, 09:39:51 PM »
maybe Califia? note the hump on top, I fabbed a box for my CB radio from fiberglass.. when i got on the air they always thought  I was a semi truck from all the background noise, there were no lip mics back in the day.  I did fab up speakers in my helmet.
Offline smdl
Re: 850T Project
« Reply #13 on: February 24, 2013, 10:00:10 PM »
Hmmm, okay, thanks.  Interesting mod for the CB!
Shaun
'61 Galletto
'24 Stelvio
Offline harrytief
Re: 850T Project
« Reply #14 on: February 24, 2013, 11:22:47 PM »
Shaun
Let me know if you need any help and remember my cache of spares. Don't forget to "rescue" the spare rear wheel fro Rosey Toes.
Harry
Offline smdl
Re: 850T Project
« Reply #15 on: February 25, 2013, 05:10:05 AM »
Thanks, Harry -- I'll be in touch.
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
Re: 850T Project
« Reply #16 on: March 16, 2013, 07:45:03 PM »
Hi, folks.
Well, I finished stripping the T down to the bare frame today, so will be starting on the sub-assemblies next.  Not surprisingly, I found that much of the bike has been worked on before, and I suspect that many aspects are not original (which is fine).  However, I would like to get a good feel for how things were originally arranged, and wonder if anyone might have some good pictures of an original bike with the seat up and the tank off?  I would especially like to see how the wiring and electrical components are configured.
Any help would be appreciated!
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Re: 850T Project
« Reply #17 on: March 16, 2013, 09:03:00 PM »
sorry, bad wide shot and it's a Convert but the cable routing is the same as a T.
Offline motoscotto
Re: 850T Project
« Reply #18 on: March 16, 2013, 09:10:17 PM »
Nice find, I am doing the same with an 1975 850T but it is in pretty bad shape, I have it torn down to the frame also, the engine will be the challenge for me, I looking at a 2 year build, I built a powder coat oven so most of the bike will be powder coated. I will post pics when there is some real progress.
1996 1100 Sport RED
1987 Blue&Cream Heritage Softail
1983 Honda CB 1000
12013 Artic Cat Red 500 ATV
1980 Suzuki GS 550 (1)
1974 Honda CL 360
1977 Honda CJ 360 T
Offline smdl
Re: 850T Project
« Reply #19 on: March 17, 2013, 12:30:30 AM »
Thanks, foto.  Hmmm, looks like a fair number of differences with some of the electrical and braking stuff having been moved down behind the side covers.  Still, this is a helpful guide.
Cheers,
Shun
'61 Galletto
'24 Stelvio
Offline smdl
Re: 850T Project
« Reply #20 on: March 17, 2013, 12:33:36 AM »
Sounds good.  Let's definitely compare notes as we go along.  I'll look forward to seeing how your powder coating comes out!
Shaun
« Last Edit: March 17, 2013, 12:34:34 AM by smdl »
'61 Galletto
'24 Stelvio
Chad M
Re: 850T Project
« Reply #21 on: May 30, 2013, 06:57:09 PM »
Hey Shaun!  Where's the updates???
Chad.
Offline smdl
Re: 850T Project
« Reply #22 on: May 30, 2013, 08:11:52 PM »
Chad.
Hey, Chad.
Hmmm, "updates" would probably be an indication that there had been some "progress".  Unfortunately, between spring yard work, fighting a horrible cold for the past few weeks, and working day and night, "progress" now seems more of a theoretical concept than a potential reality.  Hope to get back at it soon.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline dl.allen
Re: 850T Project
« Reply #23 on: May 30, 2013, 10:29:20 PM »
On the valve train clatter you might check the pushrods.  The PO on mine fitted new jugs but used the old round hole gaskets and it bent the pushrods and chewed through the metal rings on the gasket.  With the bent pushrods the valve lash was variable making crazy noises.  I fitted the oval hole gaskets and photoguzzi gave me some pushrods, Thanks!, and now it purrs like a kitten.....till the shift spring broke ::(
Offline smdl
Re: 850T Project
« Reply #24 on: May 31, 2013, 09:42:37 PM »
Thanks, dl.  I did actually get the heads off, and found that everything in the top end pretty much looked okay.  Pushrods looked fine, rockers were not worn unevenly, shafts looked okay for the most part (one maybe had a slight tight spot).  However, what I did find was that the bike has a set of Agostini gears on it, and the ring nut holding the crank gear on was almost completely backed off.  That allowed the gear to slide for and aft about half an inch, and I imagine that such movement might well have caused somr clatter.  I'm wondering if this might have been the source of the noise, possibly transfering to the cam gear and up through both top ends.  Both seemed noisy, and it was difficult to pinpoint where the noise was coming from.
As soon as I get some time, I will finish stripping the engine and see what else I come across.  I'd like to think that I have already identified the issue, though...   :D
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline harrytief
Re: 850T Project
« Reply #25 on: May 31, 2013, 10:16:49 PM »
Hi Shaun
So that is where I put my ago gear set. Glad you found them...for me? You are probably right that the backed off nut is the source of the noise. The engine was strong when I had the bike and as part of upgrading the clutch I installed the gears. Phil had told me that the engine was a rebuilt T3 that came with the bike during his ownership of it. Good luck with the project.
Harry
Offline smdl
Re: 850T Project
« Reply #26 on: May 31, 2013, 10:28:51 PM »
A loose pushrod end will clatter too.
Yes, I can imagine it would, but the pushrods all look good, and the ends appear tight.  Will take a closer look before I start reassembly.
Thanks,
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
Re: 850T Project
« Reply #27 on: May 31, 2013, 10:34:05 PM »
Hi Shaun
Harry
Hi, Harry.
Well, I'm not married to the Agos, by any means.  If you want them, maybe we can arrange a swap for something?  FYI, I actually picked up the proper tool for installing and removing them without damage.
Let's arrange a time to get together soon.  I wouldn't mind picking up that plate when convenient.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline harrytief
Re: 850T Project
« Reply #28 on: June 01, 2013, 09:16:37 AM »
Hi Shaun
I'm around all summer this year but spending all my time in the studio. I've finished the cx100/gsxr project and its turned out looking a little like a mini griso. These tonti bikes are fabulous and each iteration is just another world of possibilities. The shock and fork mods I did to the calvin over the winter have blunted my cal1400 lust. The calvin stays. I'll call in the near future and remember the spare engine/transmission I have.
Harry
Offline N.Y.zee10
Re: 850T Project
« Reply #29 on: June 01, 2013, 10:37:03 AM »
Shaun, here are some pix of the electrical components as arranged on an early 850T. I believe the placement to be as built. The wires going to the components may have likely been changed along the way. If you need a pix of something else- let me know.
