Author Topic: "Super" Lario/LM1 SB clone build w/Bubs music  (Read 94679 times)
Offline kevdog3019
Re: "Super" Lario build started (final carburation 9/20)
« Reply #120 on: November 05, 2014, 11:23:41 AM »
Found the beast was still running too lean with 165 mains so boosted it a half size to 168's. Plugs don't seem to be burning up now and are looking more tan than white. I have 170's in case they're needed. Sad day as it's been laid up to slumber for the winter. Time to get on to the "projects" part of it again. Now I just need time. I can rest now knowing the functional aspects are right where I want them. Cosmetics are next.
Kevin
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline kevdog3019
Re: "Super" Lario build started (final carburation 11/5)
« Reply #121 on: January 13, 2015, 09:11:43 PM »
Seat project started today. Cut the sheet metal and will take this to my seat upholsterer for welding, etc.  More soon.
« Last Edit: January 13, 2015, 09:13:58 PM by kevdog3019 »
'86 V65 Lario
Offline kevdog3019
« Reply #122 on: January 20, 2015, 05:56:07 PM »
Figured out the under-seat arrangement. A little over/under of the original bits and it's finished. Level and solid. Tomorrow I get the seat back to do some fitting.
'86 V65 Lario
« Reply #123 on: January 20, 2015, 07:36:26 PM »
Eager to see it!
Offline kevdog3019
« Reply #124 on: January 22, 2015, 01:20:30 PM »
Seat tacked and bent to final shape. Time to bring it back for upholstery (pic thrown in). Threw in a little piece of bling from MG on the steering head.
« Last Edit: January 26, 2015, 11:56:20 AM by kevdog3019 »
'86 V65 Lario
Offline kevdog3019
« Reply #125 on: February 01, 2015, 08:35:21 PM »
Since I'm waiting for my seat I figured I should get after the fender and mounts. Did some playing and decided on a wrap mount. There will be a rear one also.
I use this respirator from the wood shop for cutting this fiberglass. I also prefer to use this thin cutter as it creates very little dust. It also cuts very precisely.  Make the line and take a few passes to cut through. Use sandpaper to even it out.
« Last Edit: February 01, 2015, 10:21:20 PM by kevdog3019 »
'86 V65 Lario
« Reply #126 on: February 01, 2015, 10:12:47 PM »
What was the starting point for your fender Kev? That's no Lario stocker.. Is it a generic blank or.,...
Offline kevdog3019
« Reply #127 on: February 01, 2015, 10:27:14 PM »
It's Airtech stuff; both the fender and LM1 fairing.  Fender has been slimmed down a lot.  Will cut the back off after I decide exactly where I want it.  It's easy stuff to work with.  You just want to make sure you start with a fender that has the right radius to fit the wheel.  This one was perfect.
BTW... the stocker doesn't fit the Marzocchi's hence the re-make.
« Last Edit: February 01, 2015, 10:30:06 PM by kevdog3019 »
'86 V65 Lario
Offline Aaron D.
« Reply #128 on: February 02, 2015, 06:42:30 AM »
Nice job so far-but tell me, is the Lario 4 valve still a Heron design? I have little experience with the smallblocks but I'm getting interested.
« Reply #129 on: February 02, 2015, 07:11:26 AM »
Yep, it's a flat head..
« Reply #130 on: February 02, 2015, 09:00:01 AM »
Offline Dogwalker
« Reply #131 on: February 02, 2015, 09:21:41 AM »
As shown in the picture, it has a pent-roof combustion chamber.
« Reply #132 on: February 02, 2015, 11:42:58 AM »
My bad. <blush> That's what I get for typing before the coffee kicks in.. sorry.
Offline kevdog3019
« Reply #133 on: February 02, 2015, 12:40:22 PM »
New engine fumes will do that to you!  :D
GOing to pick up seat.  Stay tuned.
'86 V65 Lario
Offline Aaron D.
« Reply #134 on: February 02, 2015, 01:06:08 PM »
Thanks for the info. I wondered how they'd fit 4 valves into a Heron head with that bore!
So the next question, what do folk think, hemi or 4 valve pent roof in this application? Or is the Lario valve train too troublesome for volume production?
I just wonder because it wouldn't take much more power to make the small block kick butt in the modern world, and the 4 valver should handle emissions better.
Offline kevdog3019
« Reply #135 on: February 02, 2015, 01:15:36 PM »
Chuck's aero engine will be telling. We don't know yet what that will bring though we suspect good stuff. I like my Lario engines and their 4-valve heads, but you must proceed with caution with them. There's no reason they can't be made right. I'm hoping the measures I took with this "super" Lario hopped up 15% will fair well. I agree it doesn't take much more power to make the sb a real hoot. I hope they're listening.  :wife:
'86 V65 Lario
Offline kevdog3019
« Reply #136 on: February 02, 2015, 08:17:43 PM »
The seat is home and fits splendid. It's hard to tell, but it's a stressed tan that looks great in person. This was done locally at Mark's Upholstery in Jenison, MI..  He's a wonderful guy to work with. You'll see that he strobes the cross-stitching by going larger to smaller. I like it myself as it gives some depth and isn't perfectly uniform.
« Last Edit: February 03, 2015, 04:52:01 PM by kevdog3019 »
'86 V65 Lario
Offline kevdog3019
Re: "Super" Lario/LM1 SB clone build
« Reply #137 on: February 07, 2015, 06:30:25 PM »
Fender mounted. Thanks Chuck for the clearance specs. Around 20mm as I feel that's safe. Lots of work to get things just right. She's solid!!
'86 V65 Lario
Offline mwrenn
« Reply #138 on: February 07, 2015, 09:39:53 PM »
Looking good!!!
Offline Guido Valvole
« Reply #139 on: February 07, 2015, 09:51:59 PM »
Looking like a good, healthy runner!
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
« Reply #140 on: February 07, 2015, 10:33:53 PM »
Looks great with the brown seat, the flush headlight in that LM1 fairing, and the custom cut fender :thumb
« Reply #141 on: February 08, 2015, 06:17:17 AM »
Hopefully, the nuts on the fender don't compromise the clearance too much?
Offline kevdog3019
« Reply #142 on: February 08, 2015, 08:09:18 AM »
Yeah, that was all in the figures. There's plenty of room for something that might get picked up. There's also nothing sharp as the nut is a perfect fit to the end of the screw w/lock washer.
'86 V65 Lario
« Reply #143 on: February 08, 2015, 08:11:23 AM »
Nice job of forming the fender mounts..
Offline kevdog3019
« Reply #144 on: February 08, 2015, 08:31:48 AM »
Lots of thumb work on that as well as vice with hardwood inserts for the tight bends. I got some experience with aluminum bending on my LM fairing. I braced the entire horizontal length where the windscreen screws into the fiberglass. There's a perfect groove to fit a bar along that space. I did this so that I could make runs up to it for bracing w/o compromising the fiberglass. The windscreen puts pressure enough on it. I realized in bending that how easy aluminum is to form if you take it slow. Once you kink an area you're pretty much through.
'86 V65 Lario
Offline kevdog3019
« Reply #145 on: February 08, 2015, 08:38:51 AM »
Here's the question now; do I paint it black to (essentially) disappear, or red along with the fairing for tire jewelry?  Red would give s but more "classic" look but not sure I'm after that much "class". I need input!
Edit: I won't have a tail fender, just s tail "tidy". Maybe this makes sense to go black?
« Last Edit: February 08, 2015, 08:41:12 AM by kevdog3019 »
'86 V65 Lario
Offline kevdog3019
« Reply #146 on: February 12, 2015, 10:18:49 PM »
Did some adjusting of the taillights now that the seat is finished. Raised over an inch up under the seat.
Fab'd a mount and painted it:
Before:
After:
« Last Edit: February 13, 2015, 12:00:47 AM by kevdog3019 »
'86 V65 Lario
Offline mwrenn
« Reply #147 on: February 13, 2015, 01:12:36 AM »
Raising that plate looks a LOT better.  Funny how a small change can make a dramatic difference in appearance.
Offline kevdog3019
« Reply #148 on: February 17, 2015, 04:16:40 PM »
Alright, got her done. Fender now in black. Another check off the to-do list. Nondescript yet dressy.
'86 V65 Lario
Offline mwrenn
« Reply #149 on: February 17, 2015, 06:30:17 PM »
Oh yeah!  You are getting the baby LM look going now!  Sweet ride!
