Author Topic: Got rollered!  (Read 88233 times)
Re: Got rollered!
« Reply #90 on: September 05, 2015, 05:47:21 PM »
Do you have the lambda off on yours Pete?
But then I don't think that matters at open throttle above 6000.
Re: Got rollered!
« Reply #91 on: September 05, 2015, 05:56:08 PM »
Yup, it's Mark's Mistral Hi-pipe w/dbk map. It was absolutely spot-on with flat tappets and has fallen in a heap with the conversion to rollers. It's perfectly addressable, it's just as far as I'm concerned that is Mark's area of expertise not mine so I'm more than happy to defer to his skills and experience.
Offline lucian
Re: Got rollered!
« Reply #92 on: September 05, 2015, 06:59:55 PM »
Well, I am officially rollerized, Not a bad job thanks to Pete's well done instructions. Was shocked to see early signs of dlc failure on all 4 tappets. At only 6000 miles I didn't expect to find any , but just like Wayne, it was worse on one intake tappet. I am glad I decided to bite the bullet and do the swap. I can only wonder if a dealer would have considered this a failure and supplied the kit at this early stage and low mileage. I also found slight leakage on the valves with a dish soap and compressed air test so I removed all the valves and re lapped them, no more bubbles. Tomorrow I will check tb balance and reset tps and self learners and give it a go. I already fired it up and it is definitely way quieter. I set the valve gaps to .o15 and .o20mm I wasn't sure what they should be with the roller set up. If anyone has the factory 03 map they could share I would like to try it at least temporarily. Will post some pics soon.   Dave
Re: Got rollered!
« Reply #93 on: September 05, 2015, 07:08:35 PM »
Congrats on getting it done!  I may do the same.  For some reason, though the Griso isn't ridden nearly as much at the 1200 Sport, she is a beautiful machine ..... and part of the reason for the low mileage is that 'back of the mind' thing about the tappets (and the need to do something to make the suspension more compliant.)
Question .... are you a professional 'wrench', or do you consider yourself more of a shade tree mechanic who simply followed Pete's instructions?  How many hours were involved in 'rollerization?'  And were there any obvious 'gotchas?'
I'm looking for moral support!
Bob
Re: Got rollered!
« Reply #94 on: September 05, 2015, 07:09:52 PM »
Valves should be, depending what you read, either 0.15 and 0.2 mm or 0.1 and 0.15mm. I'm assuming that was a typo.
Generally the roller set up is much quieter than the flats, especially on A5 motors. Mine is still very noisy but I didn't re-size the rods after the big ends went west. I may yet pull the motor and go through it top to bottom just to see what's what at 100K km. it could probably benefit from new cam chains and rings anyway.
One thing I'm tempted to do is swap out the plastic oil pump gear for the steel one used on some engines. I've always hated plastic and alloy gears.
Offline lucian
Re: Got rollered!
« Reply #95 on: September 05, 2015, 08:00:02 PM »
Bob . i am definitely no pro, but I have done my own wrenching on my small engines and equipment since I can remember. Also grew up with dirt bikes and then street bikes so I have done a fair share of those as well. The whole roller swap took me nine hours start to finish but I spent a couple of those hours re lapping the valves both intake and exhaust. I had to pull the heads anyway to install the inlet shims. Actually I am still not finished as I still have to balance the tb's and possibly load a different map. The only thing I did not have was a proper valve spring compressor but I made due with a modified deep socket and a large C clamp. I will post a picture soon. As Pete said the keepers are tiny so patience is required, but his tutorial is spot on and easy to follow. Also I only removed the intake manifolds and rubber couplings and left the tb's in place on the air box, this allowed easy accesses to the cam sprocket covers and especially the little screw you have to remove for pinning back the left side chain tension blade. If I can help feel free to ask. But I only know about the 8v what I have learned here on WG, Thanks to all,,dave
beetle
Re: Got rollered!
« Reply #96 on: September 05, 2015, 08:01:57 PM »
I can send it to you if you like. Lambda on or off?
Offline lucian
Re: Got rollered!
« Reply #97 on: September 05, 2015, 08:48:14 PM »
Here is a couple of pics. Interesting the one tappet that looks scratched as if it weren't spinning. My homemade valve tool,did the job. All in all I'd call myself lucky. Thanks Mark, I think I'd like to keep the original closed loop and give it a try, I'll pm you an e mail,many thanks.   dave.
« Last Edit: September 05, 2015, 08:58:47 PM by lucian »
beetle
Re: Got rollered!
« Reply #98 on: September 05, 2015, 08:55:18 PM »
Sent (already had your email address).
Offline lucian
Re: Got rollered!
« Reply #99 on: September 05, 2015, 09:00:45 PM »
Aussies rule  :bow: Best of luck Tuesday!
beetle
Re: Got rollered!
« Reply #100 on: September 05, 2015, 09:02:39 PM »
the main thing that I changed was taking OUT some fuel from TP24 upwards. That's the opposite of what I expected, but the first run with the logger on clearly showed that it was running slightly richer (3 to 4%) with the rollers than with the flat tappets at higher throttle positions. I suppose that means the roller profile doesn't quite allow the same airflow?
Assuming equivalent torque, this suggests the roller cams provide better VE than the flat cams. Interesting.
Re: Got rollered!
« Reply #101 on: September 05, 2015, 09:04:55 PM »
It'll be interesting to see what state Mark's tappets are in.
Offline lucian
Re: Got rollered!
« Reply #102 on: September 05, 2015, 09:11:31 PM »
Pete do you think the extent of wear I found warrants further fussing? No roughness to the surfaces at all, but obviously  some dlc missing. 6000 miles, who'd have thunk.
Re: Got rollered!
« Reply #103 on: September 05, 2015, 09:16:29 PM »
Next oil change drop the sump and give it a good clean out but with such minimal wear at such a low mileage I think it would probably be uber-paranoid to do the full back-flush etc.
Others opinions may vary.
Offline Xlratr
Re: Got rollered!
« Reply #104 on: September 06, 2015, 03:32:13 AM »
Really, no hyperbole Mark, you can take mine out when you're down here and see for yourself.
Strangely enough too rich is what I thought it felt like as it doesn't break down and pop and fart, it just goes dead flat and gives you nothing. Only at wider throttle openings and above about 6,000. At lower RPM it actually feels a bit lean. Logging it will tell us.
Pete, that's what I found too. In addition to taking fuel out above TP24, I put some more fuel in from TP8 to 19 at the corresponding RPMS.
Re: Got rollered!
« Reply #105 on: September 06, 2015, 03:46:20 AM »
Well perhaps I'm not a complete idiot after all......? :D
Offline Xlratr
Re: Got rollered!
« Reply #106 on: September 06, 2015, 03:47:30 AM »
Hi Mark. I'm not so sure about the equivalent torque though. I'd love to see torque/power curve comparison of roller vs. flat tappet models on the original map. I have the feeling the roller version might have slightly less power at the top end. I understood the profile should simulate exactly the Flat Tappet lift and duration, but maybe there is a slight difference. Or maybe it's the added weight of the valve-train components?
I now have my map set up with exactly the same air/fuel ratios that I had with the flat tappets. It runs very well and very smooth, but if anything it has just slightly less "bite" at the top. It's not obvious, and I'm talking here about speeds in excess of 170kmh and approaching 200kmh, but it does feels slightly tamer at those speeds.
So maybe the VE is less efficient at higher rpms and that's why it requires slightly less fuel? Just speculating. As I say, it would be great to see some curve comparisons.
Re: Got rollered!
« Reply #107 on: September 06, 2015, 03:57:47 AM »
That makes perfect sense but I'd have to say that if there is a noticeable 'Flattening' of top end delivery something is still wrong. Even if it produces less outright performance there shouldn't be some sort of arbitrary 'Transition Point' that is detectable by feel.
There again it could be that the roller system is actually limited as you say by its extra mass and the useable profile of the cams. I really don't know.
Offline Xlratr
Re: Got rollered!
« Reply #108 on: September 06, 2015, 04:23:58 AM »
I wouldn't say there is a certain transition point or that it's very noticeable, it's just got very slightly less bite at the more extreme rpm/throttle positions. I think I have the fuelling right, but still, maybe something is possible with fuel phasing? I don't know yet. I think though that the rollers might have very slightly more power in the mid range and slightly less at the top. Just my feeling.
It'll be interesting to see what all the others say, post conversion!  :grin:
« Last Edit: September 06, 2015, 04:25:43 AM by Xlratr »
Re: Got rollered!
« Reply #109 on: September 06, 2015, 05:27:56 AM »
Amen to that. The only way we get to work this stuff is by doing it ourselves. Sooking on about how awful it is achieves nothing.
beetle
Re: Got rollered!
« Reply #110 on: September 06, 2015, 06:02:51 AM »
I was contemplating an accelerometer run with my VR3, but it's really only able to show significant changes in the torque curve. I suspect we're only looking at a few foot pounds, so a dyno would be required.
Offline brlawson
Re: Got rollered!
« Reply #111 on: September 06, 2015, 09:30:05 AM »
Kit A-$999.39 Part # 1A002060
Kit B-$1050.78 Part # 1A002063
Kit C-$1456.00 Part # 1A002082
As I have previously explained though you can make a 'C' kit appreciably cheaper by buying a 'B' kit and the shims, valve stem oil seals, inlet and exhaust gaskets and measuring the head gaskets that come off and simply buying a pair of similar thickness. The 'C' kit contains all three thicknesses of head gasket as well as those extra parts, hence its higher price. If you're doing it on your own dime why buy two pairs of gaskets you don't need? They aren't cheap!
Oh, those prices are from the AF-1 website but I'd imagine that MPH, MI or any of the other reputable suppliers and 'Good' shops will have very similar prices.
PS. Time depends on what needs to be done.
I figure I may as well be proactive and get this done since the engine is over 50,000 and running well. Give me something to do this winter.
In searching for a good place to purchase, I found that Teo Lamers has them for a very reasonable price. Substantial savings for the B kit. Fortunately, the one I need.
AF1 is always top dollar.
Right now the exchange rate is pretty good for us folk in the US:
Kit A-$999.39 Part # 1A002060 - 789.48 + 35 shipping  = $914usd
http://www.tlm.nl/webshop/en/catalogsearch/result/?cat=0&q=1A002060
Kit B-$1050.78 Part # 1A002063 - 598.55 + 35 shipping  = $723usd
http://www.tlm.nl/webshop/en/camshaft-kit-b-8v-09-10-stelvi-1a002063-moto-guzzi
Kit C-$1456.00 Part # 1A002082 - 1,155.83 + 35 shipping = $1328usd
http://www.tlm.nl/webshop/en/catalogsearch/result/?cat=0&q=1A002082
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
Re: Got rollered!
« Reply #112 on: September 06, 2015, 10:02:16 AM »
I live 12 miles from the US Moto Guzzi warehouse.
The ones from Teo Lamers on the other side of the planet would get to me faster then the ones in stock in the US I suspect.
 :sad:
Offline brlawson
Re: Got rollered!
« Reply #113 on: September 06, 2015, 10:15:52 AM »
 :sad:
They had the B kit in stock so it should be here in a week. Usually, when they show "out of stock" it takes them about 1-2 weeks to to fill an order.  They are generally on the ball when it come to shipping parts.
B. Lawson
Madison, AL
'77 Yamaha RD400
'79 BMW R/65
'10 Stelvio ABS
2000 v11 Sport
Offline lucian
Re: Got rollered!
« Reply #114 on: September 06, 2015, 12:36:04 PM »
My Griso required the thinnest of the three head gasket choices, marked with a white dash, I have the other two sets as they came with the c kit I purchased, If anyone can use them let me know, I think Pete said the middle one will work for most.  Dave
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Got rollered!
« Reply #115 on: September 06, 2015, 02:21:35 PM »
Where are the marks on the gaskets, and can you find it on the used old ones?
My kit had the middle one only, nothing to choose.
Paul
Daytona 1225, Stelvio 1151
Re: Got rollered!
« Reply #116 on: September 06, 2015, 04:19:14 PM »
I'm not sure exactly when they started colour coding the gaskets Paul, certainly not in the first couple of years of production. The way it seems to be done is when the new gaskets are stacked upright in boxes or racks someone just runs a paintbrush down the edge of them on the side that faces *Out* from the bike.
From memory it's white for the thin ones, yellow for the intermediates and the thick ones are left unmarked.
Offline lucian
Re: Got rollered!
« Reply #117 on: September 06, 2015, 04:28:08 PM »
Paul, they are marked with a  dash on the forward most point on the top surface,white being the thinnest,yellow the middle and the thickest has no marking.
The packaging was numbered as follows
thin dis. # 874621
 Middle dis. #874622
 thickest dis. # 976311
 Was yours a c kit?
Offline lucian
Re: Got rollered!
« Reply #118 on: September 06, 2015, 04:34:43 PM »
While it maybe less than brilliant, I see no reason why one couldn't reuse one of these types of gaskets. I would shellac it and slam it right back in next time.
Offline pauldaytona
Re: Got rollered!
« Reply #119 on: September 06, 2015, 04:41:19 PM »
well no paint marks on my old ones. And the C kit came with one set, not three sets, someone made me the choice easy. Did they in the beginning suppose that each time one takes of a head, you are going to measure with the special tools?
Paul
