I hesitate to suggest it because you might just do it, but....add a hydrostatic final drive? Or even more eccentric, a straight hydraulic drive? Look ma, no shaft, nothin' but hose!
Good stuff! Didn't know about the dual plug thing. Does this require different coil than the 03 EV uses? Or how does it happen? I plan to use my existing 15M ECU.Yes, Charlie, the alternator is belt driven from the drive shaft. Another wrinkle is that the timing cover is from a Convert, which is yet another crank style (bosh alternator). I'll have to check that seal. There might already be a seal made to get there with no fuss.I'm going to open the crate today and find the other stuff I didn't know.
I have intake manifolds and coils. I think I have the vent/return problem solved on paper. Still outstanding is the crank seal. I need to go from the OD of a Convert/V1000/bosch alternator-type timing cover to the ID of the Breva. I can't make out the numbers on the Convert seal. Looking for those dimensions.
Thanks, Charlie. I misunderstood your previous post. Drugs may have been involved. I thought you were talking about the breva v ev seals, not breva v convert. I think this solves that problem.
I hate to be a bother, but the choices in seals are fluoro rubber, nitrile, rubber, and viton. Any opinions on which is the better material?And Charlie -- the reason I asked about the cal III seal size in another topic is because as I understand it, the seal on the suprisa alternator-equipped tontis rides directly on the crank. It seems to be different than the others, but I can't verify that. I know the suprisa seal has a different part #.
