Author Topic: Crankshaft seizure problems with V7 II'S  (Read 60701 times)
Offline Markinlv
Re: Problems With 6-Speed V7's
« Reply #90 on: March 04, 2017, 05:28:12 PM »
Service manager = Todd?
How did you discover the grade difference?
Tiffany told me that they "cannot get" AGIP/Eni and use Motoul, but the grade difference is a surprise.
You are correct sir, I only found out about the grade difference because I asked when picking up the bike.
Offline Markinlv
« Reply #91 on: March 04, 2017, 05:29:55 PM »
Mark, when did you buy your V7 II?
Second week of January
Offline SportsterDoc
« Reply #92 on: March 04, 2017, 06:01:10 PM »
Could you have been told wrong?
Does the invoice itemize?
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
« Reply #93 on: March 04, 2017, 06:01:54 PM »
How could a dealer not be "able" to get the OEM recommended fluid, that owners in the US don't seem to have a problem getting?
« Reply #94 on: March 04, 2017, 06:04:19 PM »
Got mine Feb 10.
I emailed the service manager.   If I do not get a satisfactory reply, I will do my own service.
Still looking for headbolt torque specs.
« Reply #95 on: March 04, 2017, 06:06:33 PM »
Now I have a dilemma. I can easily do all the first service..although the "service manual" does not list head bolt torque...or I did not find it.
Well, maybe not easily, as the older I get, doing work on the garage floor is it quite as easy as it was when I was 16...54 years ago.
...and putting it on a lift, makes it easy to turn the rear tire to get to TDC to adjust valves.
Part of the list is to check plug gap, which I have already done...but the plugs should come out for TDC, anyway..although seeing the valves closed may suffice.
Main purpose of going to the dealer was to establish a relationship, should there be a warranty issue.
There are threads here (and dealers too) who can talk you through the service if desired.
And I'm not sure a single service would establish any real relationship should warranty work arise.
That said I never actually needed a warranty claim on any of my Guzzis (while they were in warranty) anyway.
« Reply #96 on: March 04, 2017, 06:28:31 PM »
Since I am in the process of retiring, I am not entirely on Social Security, so spending $ for the first service is OK with the budget.
However, since I have a tenancy to micromanage, and since doubt has been raised by Mark, the question is will ALL be done 100% correct?
If I do it myself, then I know what has been done.
I have posted on the XLForum about service from Ventura H-D and Simi Valley H-D, some years ago.
I paid Ventura for the first service, circa Dec 2002.
One of the service items is to lube clutch cable.
I was on a ride in Canyon Country (north of Los Angeles), a couple/three weeks later, when clutch pull greatly increased.
I stopped by an off-road M/C place and bought a can of cable lube.
A few minutes later, all was good...except my opinion of the Ventura H-D service department.
In the Spring of 2005, I took my XL1200 Sport to Simi H-D for new tires.
$300 mounted and balanced seemed reasonable.
As I rode away, I heard noise from the front...the axle pinch bolt(s) were very loose.
Made a U turn and "mechanic" snugged them up.
A day or two later, I was on my way to Anaheim on business, when I heard popping noises from the rear hub and the hub was hot...about 70 miles from home.
Apparently, the "mechanic" drove out the rear axle (not enough anti-seize from the factory), but did NOT replace the rear wheel bearings.
The side load on the inner races damaged them.   I did not return in the carpool lane at 70 MPH.
Never needed service from Simi Valley Triumph/Yamaha/Suzuki, as I did plug and oil changes (more often than suggested) on the Bonneville.
However, when I had a new tire mounted at a place in Las Vegas (one year and 7,000 miles), just before a ride from Las Vegas to Simi and back, I found out how good a job was done on balancing.
Not that I had any business doing 108, but that was the "I can feel it is not balanced" speed, when the rear started hopping.
On the TW200, I did a couple oil and filter changes, then traded it in after 45 days and 900 miles.
Sixties through eighties, no one else touched any one of the 10 bikes.
Think I am talking myself into doing it my self.
Anyone got torque specs on V7 II head bolts?
« Reply #97 on: March 04, 2017, 06:38:47 PM »
Pete Roper or GuzziSteve are dealers/techs and they can confirm whether or not anything changed, but I'm betting it's the same V7I vs V7II.
If so there's a detailed write up about the first service including head retorque specs and suggestions in a thread I wrote.
I'll search for it.
Edit, this should help:
http://www.wildguzzi.com/forum/index.php?topic=60261.0
« Last Edit: March 04, 2017, 06:45:04 PM by Kev m »
« Reply #98 on: March 04, 2017, 06:56:32 PM »
I'll search for it.
Thanks, Kev, you have been a lot of help
However, the link just took me to log-in and the home page.
« Last Edit: March 04, 2017, 06:58:36 PM by SportsterDoc »
« Reply #99 on: March 04, 2017, 07:00:30 PM »
Nuts, works for me weird.
Looks like the same link. Why is it working for me?
« Reply #100 on: March 04, 2017, 07:03:28 PM »
OK I cheated and bumped it.
But maybe this will work too:
http://wildguzzi.com/forum/index.php?topic=60261.0
« Reply #101 on: March 04, 2017, 07:06:08 PM »
Took me right to it.
M8 head botls are 28 Nm = 20.6 ft lbs
M10 are 42 Nm = 30.9 ft lbs
After looking at the vent hose spring clamps, I see why you suggested lifting the tank a few inches.
With plugs out, why not rotate tire to get TDC, rather than remove front engine cover?
Will go back and re-read.
« Last Edit: March 04, 2017, 07:23:12 PM by SportsterDoc »
« Reply #102 on: March 04, 2017, 07:38:37 PM »
Mark
I just (~5:30 PM) got a call from Todd, the service manager and I was satisfied with the conversation.
He had not received my last two emails and did not get the two I sent him while we were talking.
His head tech is Mario, who did a shift lever link adjustment before I rode away on Feb 10 and I got a good impression from him.
I will have a discussion with Mario, before signing the authorization on Tuesday.
Offline DaSwami
« Reply #103 on: March 04, 2017, 10:28:49 PM »
Well, ain't this some crap.  V7II Stone 1285 miles runs awesome.  V7II Special 50 miles but I will keep a close eye on it as the miles pile up.
I LOVE these bikes, sold a CB1100 and a Triumph Scrambler to keep them because those bikes don't stir the soul like the Guzzi.
But I HATE problems, esp. those of this magnitude.
Offline v65tt
    • Streffords
« Reply #104 on: March 05, 2017, 03:03:12 AM »
Wrong grade, used 10w-50 in engine oil as opposed for MG recommended 10w/60.  I asked about it and the service manager was just condescending.  If I felt more confident or could find a good video on checking valve clearence I would just do it myself.
10w50 is suitable for a v7 engine, thats what i run mine on.. In the cold damp uk using 10w50 seems to dramatically lower the the amount of majo in the oil.
Remember manufacture have to spec and oil that is suitable for use in cold damp countries as well as scorching hot countries.
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
Offline leafman60
« Reply #105 on: March 05, 2017, 07:11:11 AM »
Here's where they were all made-
« Last Edit: March 05, 2017, 07:14:03 AM by leafman60 »
Offline sib
« Reply #106 on: March 05, 2017, 07:35:09 AM »
That shifty-looking guy in the first pic is the disgruntled employee who sabotaged the engines by leaving out the crankshaft thrust washers.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline DaSwami
« Reply #107 on: March 05, 2017, 08:15:48 AM »
Oddly enough, that explanation would give me the most comfort.
« Reply #108 on: March 05, 2017, 09:39:42 AM »
Now, you are making me go back to the beginning to find out if the issue is missing or too thin!
Sigh!
Offline SmithSwede
  • I don't want a pickle
« Reply #109 on: March 05, 2017, 10:34:07 AM »
Looks like the eagle-eyed guy in the suit has spotted the shifty guy.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline leafman60
« Reply #110 on: March 05, 2017, 11:49:15 AM »
The guy in the suit is the head of all production for Moto Guzzi.
« Reply #111 on: March 05, 2017, 12:24:08 PM »
He's just asking the other why all those thrust bushings are on the floor.
Offline waxi
« Reply #112 on: March 05, 2017, 12:53:04 PM »
Phahahahahaha... :grin: :grin: :grin: :laugh: :laugh:
Moto Guzzi Nevada, 1998
Offline jpv7
« Reply #113 on: March 05, 2017, 02:30:50 PM »
Don't take the timing cover off.  Just rotate the rear wheel with plugs out.  Simple.
« Reply #114 on: March 05, 2017, 05:23:02 PM »
I don't know who you're talking to, but if it's Doc he's got a wet alternator so I'm thinking there's no way he was thinking of taking the timing cover off lol.
Offline jpv7
« Reply #115 on: March 06, 2017, 12:36:51 PM »
SportsterDoc see previous post
« Reply #116 on: March 06, 2017, 02:18:48 PM »
Understood, thank you
« Reply #117 on: March 06, 2017, 05:28:19 PM »
I know but if you read that post it was in response to the link to my break-in service thread where we'd already covered that wasn't an option on a wet alternator bike anyway.
Offline waxi
« Reply #118 on: May 07, 2017, 03:17:23 PM »
Anything new regarding missing thrust washers? Are we any closer on isolating this issue via VIN?
Offline jpv7
« Reply #119 on: May 07, 2017, 09:24:52 PM »
Dealer up here seems to think it only affects V7ii Stones.  I haven't yet heard of a Special or Racer having this issue, but please correct me if I am wrong.  Does it make sense that the Stones are the first off the assembly line??  Could that be why?
