Author Topic: 1977 Le Mans running and on the road  (Read 368448 times)
Re: 1977 Le Mans Rebuild getting started
« Reply #240 on: November 02, 2017, 10:11:15 PM »
Fitted a pair of new repro rubber hand grips, the original type that have almost no padding and leave your hands numb
And I had a set of repro decals for the original switches, some of the original decals were missing or faded out, these are a decent match and cheap
Gregory Bender made me a complete new wire harness and all of the sub harness kits, Greg makes perfect copies, if you are rebuilding a Guzzi Greg can make a harness for you, all models.
http://www.thisoldtractor.com/for_sale_wiring_harness.html
I fitted the main harness, the sub harness kits yet to go in
« Last Edit: November 02, 2017, 10:14:59 PM by canuck750 »
Offline Groover
    • Scooteropolis
« Reply #241 on: November 03, 2017, 07:15:48 AM »
Looking great!
« Last Edit: November 03, 2017, 07:18:03 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #242 on: November 06, 2017, 10:50:48 AM »
I continue to install the sub harness kits, checking continuity on the RH switch I have a dead line, so I did what I should have done before fitting the switch, pulled it apart to find a lot of corrosion,
A fine wire brush cleaned up the contacts and I spliced in Greg Benders sub harness to send new wires back to the multi pin plug, fitted a new ground lug contact to the bars and it seems to be solved
Lesson learned again, 40 year old bike and everything and I do mean everything needs to be disassembled, checked, cleaned, replaced etc.....
Offline Rick4003
« Reply #243 on: November 06, 2017, 11:15:31 AM »
Looking great Jim, it will be one fine machine when you're done. And I could not agree more with your statement above. All the issues I had with my bike were almost exclusively connected to parts which I thought were good enough and then didn't take apart. So yeah lesson learned EVERYTHING needs to be taken apart and checked. Even the much newer parts on mine like the clutch mastercylinder and so on.
Looking forward to see the next installment of your build. I'm following along with interest even if I don't post everytime. And I'm sure I'm not the only one to do so.
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
« Reply #244 on: November 08, 2017, 10:27:03 PM »
I received some new Dellorto carb parts today from the world wide Laverda Guru and all around great guy Wolfgang Haerter - Columbia Car and Cycle in Nakusp British Columbia, Canada. Wolfgang stocks an amazing inventory of NOS Laverda parts and a very big stock of Dellorto, CEV, Tomaselli, IKON shocks and other lines of Italian motorcycle parts.
http://www.laverda.ca/
Wolfgang ships world wide and he can find obscure parts for many Italian bikes.
My Laverda 750 SF1 uses Dellorto PHF 36 carbs similar to those on the Le Mans and I had a hard time getting the Laverda to idle and take off smoothly, Wolfgang replaced the atomizers and slides along with O rings, gaskets and fuel valves, needles and jets. Wolfgang tells me that on the non-filter bikes the Dellorto atomizers are due for replacement after 30,000 miles and in most cases the slides are badly worn. Wolfgang sent me new 60/3 slides but the new ones need some machining, the castings on the underside of the slide are too wide for he old carbs, simple machining required
old slide on top, new on the bottom
middle slide after machining
The original slides on this LeMans are pretty scored and the new ones fit much tighter. Hopefully these rebuilt Dellortos will provide smooth idle and crisp running.
Offline Groover
    • Scooteropolis
« Reply #245 on: November 09, 2017, 08:23:22 AM »
Crazy to see the many subtle variations of the same part. Did you have to build-up somehow the slide/wall you machined out?
What do those slide walls go over? I don't have a carb in front of me, and my brain isn't pulling up any recent memories of what that carb body looks like in those spots.
1980 Vespa SI Moped
« Reply #246 on: November 09, 2017, 09:47:08 AM »
Nothing has to be built up, only machined away. The slide base is flat on one side and 'cut away' on the opposite. The cast carburetor body is machined to accept the diameter of the slide + clearance, in the base of the carb along the receiving 'flat' side there is a recess machined into the carb body that the 'wall' of the slide (visible form the underside of the slide) will nest into. If the tabs on the new slide are not machined off the slide can not fully nest into the carb body and the slide will not fully close.
This is the closed side (non cutaway side) of the slide in the fully closed (off) position
Opposite (cut away) side
When the slide of fully closed the flat base of the slide makes contact with bottom of the cast carb body ' shutting the door'
The idle speed screw fits into one of the cut out ramps that is next to the tab to be machined back.
I don't know why Dellorto cut a ramp on each side of the slide.
s for why these new slides don't fit out of the box, well Dellorto must have changed the carb body casting to accept the tab mass.
Scored and sloppy slides leak air, as air gets by the slide the engine speed picks up.
Offline Groover
    • Scooteropolis
« Reply #247 on: November 09, 2017, 01:12:30 PM »
Ah, that's it. The ramp for the needle, makes sense. Having it on each side is likely to accommodate the same barrel/part for both D or S (right or left) carb bodies. Will the steep ramp like that be a problem? Will you need to have a fatter, more rounded (blunt) adjustment needle tip?
I think they exist, probably because of these variations...
« Last Edit: November 09, 2017, 01:14:29 PM by Groover »
1980 Vespa SI Moped
« Reply #248 on: November 09, 2017, 02:45:51 PM »
I will let you know once the new atomizers arrive and I can get the carbs back together
Jim
« Reply #249 on: November 10, 2017, 10:04:07 PM »
I removed the terminal connectors from the alternator wire harness to slide the reproduction rubber boot over the loom,
Refitted connectors
Connected the alternator wires to the terminals
And then installed the cover, rubber boot fits into the groove in the alternator cover
New ignition switch
Installed the switch into the steel holder and fitted a repro rubber cover
Starter wiring and neutral indicator
The bike was missing the brake reservoir level indicator cap, found a good used one, cleaned the terminals up
Waiting on parts to finish a lot of jobs off, hopefully they arrive next week.
Offline balvenie
« Reply #250 on: November 11, 2017, 03:04:55 AM »
Lovely :grin: :thumb: Thanks Jim.
Oz
04 Cali
Offline TRw1
« Reply #251 on: November 11, 2017, 05:02:46 AM »
Great stuff!!
« Reply #252 on: November 11, 2017, 09:08:16 AM »
This thread is like a Bible for me, as a guide for my Mk 2.
Utterly  invaluable...
Offline thomas
« Reply #253 on: November 11, 2017, 12:16:03 PM »
Hi
Popular wisdom reckons it's a good idea to rotate the alternator stator by 120° such that the brush holder moves from the 12 o'clock position to the 8 o'clock position.
When it is in the 12 o'clock position riding over a bump can cause the brushes to momentarily break contact with the sliprings and this is not a good thing. I think this is also mentioned in Guzziology?
Doing this will also give the extra length of the wiring somewhere to go.
regards
Thomas
SNIP
SNIP
Guzzi riders represent the ragged fringe of motorcycling!
1980 Guzzi SP1000 & 1979 Guzzi 850 LeMans II
1969 Honda CB750 Four & 1971 CB750 Four & 1977 Seeley CB750F
1996 Yamaha YZF750SP
1983 Bimota KB-3
1966 Ducati 50 SL/1
1938 Miele 98cc & 1955? Miele 50cc
« Reply #254 on: November 11, 2017, 06:23:06 PM »
Hi
regards
Thomas
Great tip, thanks Thomas,
time to rotate the stator!
« Reply #255 on: November 12, 2017, 05:02:53 PM »
I got a new choke lever from Columbia Car and Cycle, had to scratch my head for a while to figure out how it comes apart to get new cables onto the fitting, flip the lever into full open and then unspin the lever part form the body and pull he lever end free of the cylinder
Powder coated the two bracket parts
Bolt the cylinder head bracket to the cylinder clamp
And attach the assembly to the left hand cylinder head
I dug the original seat out of storage, cleaned it as best I could then applied three coats of liquid black shoe polish and shoe protectant clear coat, looks much better, still worn but it has no rips and its original, I am still going to try and repair the new reproduction but not holding my breath
Attached the signal light extensions Greg Bender made up for me, zip tied the separate wires together, fitted new rubber seat bumpers
And its on the bike
« Reply #256 on: November 12, 2017, 07:08:36 PM »
This thread is like Zen Meditation for a Guzzi owner!
Seeing your attention to detail and the  fantastic results calms my soul...thanks for sharing it!
« Reply #257 on: November 12, 2017, 11:16:42 PM »
I would not presume to pick anything you have done.
Is the turn indicator lens upside down for a reason ? This is the best thread I've ever seen on this topic, and thank you for your guidance.
Huzo.
Offline Groover
    • Scooteropolis
« Reply #258 on: November 13, 2017, 09:33:01 AM »
Is the turn indicator lens upside down for a reason.
I have a feeling Canuck750 makes these "mistakes" to see if we are actually paying attention.  :grin:
1980 Vespa SI Moped
« Reply #259 on: November 13, 2017, 10:36:58 AM »
Huzo.
Good eye, hadn't noticed that until now, need to check the other 3 :wink:
« Reply #260 on: November 14, 2017, 05:34:30 PM »
I got this reproduction instrument bezel in today's mail, unfortunately like all the other ones listed online this one has the extra hole cut out for the center mount ignition key, post Le Mans MKI.
So I need to come up with a plan to seamlessly cover the key opening
So that it looks like this
Both the original and the repro have the cast vertical ridge centred on the bezel (painted white on the repro).
I am considering cutting out a flat section of the old bezel, shaping it and gluing it over the opening on the reproduction part.
Any other ideas to make a hole go away that I have not thought of?
On another front the Electronic Ignition also came in from HMB in Germany,
I have never trued the Newtronic ignition but have fitted the Dyna to at least four Guzzi Tonti bikes with dual point distributors. This one is a little different, but it has good simple instructions, anyone have any real world experience with these and have any tips on use?
« Last Edit: November 14, 2017, 05:43:00 PM by canuck750 »
Offline balvenie
« Reply #261 on: November 14, 2017, 09:31:08 PM »
As for attaching/gluing a flat part over the hole, I can think of two options. 1) Use a circular piece which just covers the hole. 2) make a bigger, six sided piece to correspond with the whole flat area around the hole and glue that.
               Good luck Jim :thumb:
Oz
04 Cali
Offline jvb
« Reply #262 on: November 14, 2017, 11:50:21 PM »
Or you can cover with Falcon logo MG part number 17517700 as used as the steering stem bung (30mm)
upload multiple pictures
. Ignition hole 22mm.
Nice build.
Offline TRw1
« Reply #263 on: November 15, 2017, 05:42:43 AM »
I was thinking a tight fitting rubber bung may work well
« Reply #264 on: November 15, 2017, 09:33:16 AM »
Good ideas, I think I will see if I can find a plug of some sort, the MG cap is nice but I don't want to draw attention to the fix
Offline Rick4003
« Reply #265 on: November 15, 2017, 02:55:19 PM »
You could turn up a plug in your lathe out of black delrin or something similar and vapourblast it to get the same finish as the original dash has.
-Ulrik
« Reply #266 on: November 15, 2017, 11:05:50 PM »
Parking the instrument bezel while I mull over what to do, I may cut out the whole solid piece off the old one and then mate it to the new one, its an all or nothing approach...
So lets build some carbs, I apologize in advance, this is going to take a while .......
the new atomizers and needles showed up today, lots and lots of small parts
These are the old ones being replaced, most of them look not bad but the minute wear won't be visible to the eye and if the bike doesn't run right then what's the point of rebuilding everything else
Float valve seat gasket
Screw in the brass seat and then thread in the new atomizer
Main jet holder
New main jet - 145
This part, don't know what its called
low speed jet
new fuel filter
new gasket on the fuel fitting bolt
New mixture screw, spring, washer and O ring
Choke jet with a new O ring
This jet that fits into the top of the accelerator pump body
idle speed screw and spring
And this two piece brass part with two O rings
New fuel valve clipped t the float
Setting the float height
Temporary set the new choke plungers and springs
New tiny O ring on the choke cable guide body
New needles, clip on 2nd position
New O ring on the cap
Secondary throttle cables fitted through the slide, then the needle and clip
New diaphragm and gasket
Remove the lever set screw
Pull out the shaft
Then remove the felt seal
Grease the seal and then fit it back into the cap
Fitted the new Teflon washers either side of the shaft,, tighten the set screw and replaced the top cap.
The final touch new screended intakes
Hopefully they function as good as they look
That's a serious looking carburetor
« Reply #267 on: November 15, 2017, 11:35:31 PM »
Bugger it!
It's official, you are in a different league. The fact remains that if your tutorial is followed, similar results should be achievable, but I don't think I'm that good.
(By a fair margin)...
I've posted a few things that have grown some legs, and there's been other beauties, but this is the best thread I've seen, bar none...
As motivation....?
Un paralleled. :bow:
Offline TRw1
« Reply #268 on: November 16, 2017, 06:04:44 AM »
It's been a long time since I touched carbs....brought back a lot of memories looking at the build up.
Those carbs do look the business!!!
« Last Edit: November 16, 2017, 06:06:21 AM by TRw1 »
« Reply #269 on: November 16, 2017, 02:42:05 PM »
You can and will produce a great restoration, tackle the work in segments, completing one assembly at a time to keep interest and momentum going.
Looking forward to seeing your LM II, they are rare beasts, I have seen a few CX100's but real LM II's are very rare over here having never been officially imported to North America. I had a chance to buy one two years ago close to me in Canada and passed, I think I made a mistake and should have bought it. I have seen pictures of an original white LM II and I think they look fantastic.
Cheers
Jim
