Author Topic: The New Improved GuzziDiag Tutorial  (Read 546556 times)
Offline Speedysheep
Re: The New Improved GuzziDiag Tutorial
« Reply #150 on: November 25, 2019, 12:27:10 PM »
Downloaded Guzzidiag to my Mac to reset the TPS on my V85 after installing the heated grips.  When I open the application it dies immediately.  This is on an old MacBook Air running High Sierra.  Tried it on a newer MacBook Pro with the same result.
« Reply #151 on: November 25, 2019, 01:20:33 PM »
There is no TPS function to reset with the 7SM system. You do 'Handle' and 'Throttle' self learning which is the calibration for the demand sensor but if the system is working as it should just leave it alone.
Offline Speedysheep
« Reply #152 on: November 25, 2019, 03:00:17 PM »
Guzzi’s instructions for the grip install say to reset the TPS, as the demand sensor is replaced with the grips.  I’ll see how it runs without the reset.
Was really just wondering if there’s an issue with the Mac version of GuzziDiag.  I can’t get it to run on either my personal or work laptop.
« Reply #153 on: November 25, 2019, 03:16:48 PM »
I believe this is a fairly common issue with Macs. Dunno what the solution is, sorry.
If you're installing the grips then doing the retraining is probably a good idea.
beetle
« Reply #154 on: November 25, 2019, 04:26:35 PM »
For Mac, you need to put GuzziDiag in the applications folder.
Offline Speedysheep
« Reply #155 on: November 25, 2019, 05:08:39 PM »
Thanks, Beetle.  That did it.
Offline Speedysheep
« Reply #156 on: November 25, 2019, 05:55:29 PM »
Unfortunately, I’m still not feeling the love from GuzziDiag.  I get a blue light on the Loneloc cable, GuzziDiag shows a comm port, but it just won’t connect.  Not sure what the issue is.
beetle
« Reply #157 on: November 25, 2019, 07:12:54 PM »
Have you installed the drivers?
OSX 10.9 and higher drivers:
http://griso.org/FTDIUSBSerialDriver_v2_4_2.dmg
OSX 10.3 a 10.8 drivers:
http://griso.org/FTDIUSBSerialDriver_v2_2_18.dmg
Offline Speedysheep
« Reply #158 on: November 25, 2019, 07:18:38 PM »
Thanks, Beetle.   I’ll try that tomorrow.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #159 on: November 25, 2019, 09:09:45 PM »
for a Mac, are the drivers also installed in the applications folder?
on a windows machine, should all the downloaded software be installed in the same folder?
Thanks in advance!
2026 Beta Syncro 250
1994 DR Skorpion
beetle
« Reply #160 on: November 25, 2019, 10:02:10 PM »
MacOS installs the drivers wherever MacOS installs that stuff. You simply open the DMG file that you downloaded, and run the PKG installer by clicking on the file.
For Windows, GuzziDiag will run from anywhere. It doesn't need to be "installed". I usually put them all in the one folder for convenience.
beard
« Reply #161 on: November 26, 2019, 12:44:06 PM »
The program needs write access to the directory.
Windows: don't copy them below c:\Programms
Best: make a new folder below the home directory
This is valid for all OS.
Offline MMRanch
  • MMRanch
« Reply #162 on: December 03, 2019, 08:45:46 PM »
First of all , "Thank you fellers for all this input"  :grin:
So , I had an opportunity to hook-up my V-9 to my computer today for the first time .   I was able to save a copy of my map .   :grin:
All went good till , it came time to pick a bike ... mine wasn't listed ?   in fact neither of my bikes were listed the V-7II or the V-9 .
 So ... Where did I go wrong ?
« Last Edit: December 03, 2019, 08:56:52 PM by MMRanch »
2016 V7-II Stone
beetle
« Reply #163 on: December 03, 2019, 09:01:39 PM »
You should select V7 Stone or V7 Special.  For all intents & purposes, ECU-identical to the V9 & V7III.
Offline MMRanch
  • MMRanch
« Reply #164 on: December 03, 2019, 10:24:39 PM »
 :cool:
Beetle , you are so appreciated !     If we are ever at the same place at the same time , your going to have to let me buy you lunch .  :smiley:
My V-9 (Pearl) currently has no problems .
Will the Guzzi Diag. "Program" a spare Key ?   I have one that came from "Keys for your Ride" , its Pre-Cut and is Chipped for the V-9.  I can use it for a spare now ... but I have to enter my code every time and a light flashes the entire time.
2016 V7-II Stone
beetle
« Reply #165 on: December 03, 2019, 11:02:16 PM »
No, it can’t. The new key will need to be programmed by a dealer. I’m pretty sure you can’t program it via the dash like some other models.
Offline GonzoB
    • Gonzo Projects
« Reply #166 on: December 04, 2019, 04:58:46 PM »
I'm just about to make my own connector cable for my '07 Breva 750. I think these are the connections, can anyone confirm?
Diag connector:
Guzzi Red wire - from ECU pin 10 - L-line - to OBD2 pin 15
Guzzi Brown wire - from ECU pin 9 - K-line - to OBD2 pin 7
Guzzi Blue wire - Ground - to OBD2 pin 4 and 5
Separate:
Guzzi +12V - to OBD2 pin 16
Is a separate ground wire needed from the battery, or is the Blue wire sufficient?
Gonzo
My '07 Breva 750 Projects: MCC cruise - Luggage - Shorter Shocks -
Offline GonzoB
    • Gonzo Projects
« Reply #167 on: December 06, 2019, 03:33:43 AM »
...And can anyone confirm if the ELM327 v1.5a works with GuzziDiag? I know the unit works, as I've used it with Ubuntu and my Hyundai, but I want to know if there's something special about GuzziDiag that might make it not work.
Thanks in advance...
Gonzo
« Last Edit: December 06, 2019, 03:35:02 AM by GonzoB »
beetle
« Reply #168 on: December 06, 2019, 04:08:27 AM »
Quote from: GonzoB
Diag connector:
Separate:
Looks right. No separate ground required.
Quote from: GonzoB
No, it won't.
Offline GonzoB
    • Gonzo Projects
« Reply #169 on: December 06, 2019, 04:21:06 AM »
Thanks Beetle.
Will have to get a different one.
Gonzo
beetle
« Reply #170 on: December 06, 2019, 04:25:59 AM »
You can't use a dongle. Needs to be a hard serial connection.
Offline GonzoB
    • Gonzo Projects
« Reply #171 on: December 06, 2019, 02:31:07 PM »
Not sure what you mean by "hard serial". I was going to get a USB to OBD2 adapter with the built-in serial chip (as discussed in this tutorial). Do you mean don't get a wireless one?
Gonzo
beetle
« Reply #172 on: December 06, 2019, 02:40:21 PM »
Yes. Sorry for any confusion.
Offline bigbikerrick
« Reply #173 on: December 11, 2019, 04:01:05 AM »
I have a 2017 Griso ,and the original owner that I got it from had a Beetle map installed. The bike runs great, but I was wondering, if I need to take it to the dealer for warranty work, should I take out the beetle map before taking the bike in? I am wondering if they would make issue, or make a note on their computers that would affect my warranty? Would they be able to tell my bike has a beetle map?
  Another question, If needed, where would I get the "stock map" from to load it into the bike's ecu?
Rick.
beetle
« Reply #174 on: December 11, 2019, 04:22:36 AM »
Yes. They can tell if they bother to look. There's a way around it, however. The Writer has two text boxes where you can enter the date and tester values. The Writer "stamps" the map with these values. You can use a date more suited to the manufacture date, and a 'tester' name that won't alert them. The PO may or may not have done this when loading the map. If you connect with GuzziDiag, the values will be listed in the 'information' box.
I can send you a factory map, but you will have the same issue, unless you enter a date more representative of the bikes manufacture, and a 'tester' name that won't give away your terrible secret.
Offline jacksonracingcomau
« Reply #175 on: December 11, 2019, 04:30:15 AM »
 :bow: :bow:
:bow:
Kin suave
« Reply #176 on: December 11, 2019, 12:43:01 PM »
Thats awesome, Beetle! Its always good to have an "Ace in the hole"  :laugh: in case the situation arises. I already have a "tester" "name ready to go. how does Riccardo Sarducci sound?
Rick.
beetle
« Reply #177 on: December 11, 2019, 02:22:30 PM »
 :laugh:  :evil:
Tee hee! I don’t think that’ll hold water. For Griso’s, I suggest “salaprovag” (without the quotes, of course).
Offline GonzoB
    • Gonzo Projects
« Reply #178 on: December 20, 2019, 02:44:21 PM »
I read the tutorial, received my Lonelec device and connectors, plugged them into the bike and my Linux 64 laptop and .... it all works first time!
OK, so now what do I do with this?
What should I tweak or check on my 07 Breva 750 (completely stock incl exhausts)?
Is there a better map?
Gonzo
Offline Rapier
« Reply #179 on: December 21, 2019, 06:07:33 AM »
Please pardon the ignorance...
I am an IT guy so the instructions seem right as rain. But I am new to Guzzi and not much of a gear head (willing to learn anything).
What I am wondering is the scope of the various software.
I understand that if you are looking to solve an issue (throttle / idle / ECU) or have swapped to a new exhaust this can become important. What other information will this setup give me? Is a full diagnostics suite that can assist in running down other issues?
Thanks for the patience!
Rapier
Chapel Hill, NC, USA
2018 Moto Guzzi V7 iii Rough
2017 Yamaha XSR900
